ТЕМА: Перечень тюнинг компаний
Перечень тюнинг компаний 2 года 4 мес. назад #308384
  • Макс
  • Макс аватар
  • Оффлайн
  • Подробности
    • Спасибо получено:156
    • Dodge Ram 2500 (2002—2008)
На cumminsforum обнаружил перечень тюнинг-компаний по специализации, мне кажется полезно:
List:
1.Gauges- Pyrometer, Boost, Rail Pressure, Fuel Pressure, Tranny temp (Auto)
- Mechanical
- Isspro
- Autometer
- Glowshift
- Eletrical
- Edge Cts
- H&s
2. Fass / Airdog / Raptor/ - Lift Pump
Fass Pumps (Electrical Pumps)
-Fass 95 Under 550hp
-Fass 150 600-900hp
-Fass 220 900+ Hp
Air Dog Pumps ( Electrical Pumps)
- Air Dog 100 Under 600 Hp
- Air Dog 150 550-800Hp
- Air Dog 165 550-900Hp
- Air Dog 200 900+Hp
Fuel Lab
GDP Fuel Boss
3.Auto Tranny
Builders:
- Ats
- Garmon Transmissions
- Suncoast
- Revmax
- Monster Mike
- Goerend
- DTT
- FirePunk
450-550: Tripple or good single disk Torque Converter, Valve Bodie
550-650: Torque Converter, Valve Bodie, Billet input,Billet Flexplate
650-750: Torque Converter,Valve Bodie, Billet input and Output, Billet Flexplate
750-1000: Triple Disk Torque Converter, Bilelt Input/Output/Intermediate, High Pressure Valve bodie, Billet Flex Plate
4. Manual Tranny- You guys are EASY just get a Dual/Tripple Disk Clutch
- South Bend
- Valair
- Kenny's pulling Clutches
5. Tuner:
Programmer:
03-05: Smarty jr, Smarty Sr, Smarty UDC
06-07: Efi Live, Smarty Jr, Smarty Sr, H&S, Smarty UDC
Downloaders: Edge Juice With Attitude, Bully Bog,Banks
6.Cp3-
-Motorsports Diesel
-Floor it
-Industrial Injection
- Fleece
*Arson 3: Good to 600 hp
*Bag Of Parts:
*Dual cp3: 600 to over 1000hp
*Modded cp3: 600+
7. Air Horn Optional
- Afe
- Thrasher
- Hellman
- Banks
- Bd
- CFM Plus
- Pusher Intake
8. Injectors: Depends on ur build
Each company rates there injectors different. Some rate them in Hp other in Liter Per Minuite (Lpm), others rate in Percentage Overs.
- Builders
* Exergy
- 50% over 100hp
- 100% over 200hp
- 150% over 300hp
- 200% over 400hp
* Smarty BBI Injectors
- Stage 1
- Stage 2
- Stage 3
- Stage 4
* Mass Flow Engineering
- 50% over 100hp
- 100% over 200hp
- 150% over 300hp
- 200% over 400hp
* Motorsports Diesel
* Industrial Injection
* Dynomite Diesel Performance
- 50hp
- 90hp
- 120hp
- 180hp
- Custom Injectors
35-90 hp:400-550hp
90-120 hp: 500-700hp
120-200 hp: 700-1000hp
9.Head Studs
-Arp 425 Up to 75 psi
-Arp 625 over 75+ psi
-H11 Studs
-13mm Studs
-14mm Studs ( Requires Block to be predrilled and Tapped)
10. Exhaust Manifolds-
-Ats
-Steed Speed
-Bd
-Stainless Diesel
-Afe
11.Turbos: The turbo combination that are listed is with appropriate fuel and tuning.
- Borg Warner
- Ats
- Stainless Diesel
- Bulleseye
- Ed
- FI
Singles-S300 Based Turbos: T3 Frame
62/65/12:400-550 hp Real quick Spooling
62/71/14: 400-575 Hp Quick Spooling
63/68/12:400-600 hp Still pretty quick spooling
63/71/14:400-700 hp Little bit Slower Spool
64/71/14: 550-700hp
64/74/14: 550-750hp
66/71/14: 550-800hp
66/74/14: 600-800hp
Twins:
Stocker/s475: 350-700 Hp Great for Towing and Daily Driving
62/s475: 400-800 Hp still quick Spool and Good Daily Driving
62/s480: 400-800 Hp
63/s475: 400-800 Hp
63/s480: 400-900 Hp
64/S480: 600-1000 Hp
66/s483 or s488: 700-1100 Hp
S400 Based Turbos: T4 Frame
Billet Wheels and Race Covers will Help With high Hp Numbers out of Each Setup
S464: 500-650 Hp
S465: 575-700 Hp
S467: 675-825 Hp Best Daily Driving S400 Turbo
S471: 700-850 Hp
S472: 700-875 Hp
S475: 750-875 Hp
S478: 750-925 Hp
S480: 800-1000 Hp
i1176.photobucket.com/albums/...dOil/turbo.gif
12. Cam
-Hamilton
-Colt
13.Push rods and Valve Springs
- Hamilton
14. Balancer
- Fluid Dampner
- Ati Balancer
15. Intercooler: 700+ hp If you have the platic ends of the intercooler upgrade soon as u can
- Ats
- Bd
- Banks
- Hellman
- Afe
- Mishimoto
HTT
16. Ladder Bars/ traction bars for racing or to get rid of Wheel Hop
-Cal Tracs
- GDP Ladder Bars
17. Head Work.
- Valve Springs
- Modifing Valves
- Port and Polishing
- Side Draft Intakes
* Hellman
* Banks
* B&B Tooling
* ZZ Fab
18. Water/Methanol Injection
- Snow Performance
- AEM
19. Nitrous Set-Ups
-DEI
-Nitrous Express
-TS
20. Injector and Turbo Matching
Turbo's: S300 Frame
*62-63mm Turbo 30-90Hp Injector
*63-64mm Turbo 60-100Hp Injector
*64-66mm Turbo 100-200Hp Injector
Turbo's: S400 Frame
*S469-S475 Turbo 120-200Hp Injector
*S475-S480 Turbo 200+ Hp Injector
Twins:
*Stocker/475 Set up 30-120Hp Injector
*62/s475 Set Up 60-150Hp Injector
*63/S475 or S480 90-200Hp Injector
*64/S480 or S483 100-200Hp Injector
*66/S483 0r S488 150-300Hp injector
21. If you plan on running 800+ truck.. then its mandatory to get another vehicles just in case the truck breaks
ENGINE BUILDS
Blocks:
- 5.9
- 6.4 (6.7 Block with 5.9 crank)
- 6.7
- Custom Stroker Builds
Rods:
- 12v Rods ( Some people Shop peen and Polish these Rods)
- Carillo Rods
- Split Cap Rods
- Forged Rods
- R&R Rods
- Mikes Rods
Pistons:
- Fly cut Pistons
- 03-04 Bowl Design Pistons
- 04.5-07 Bowl designs Pistons
- Monotherm Pistons
- Coated Pistons
- Marine Pistons
- Custom Pistons
Girdles:
- 12mm Girdle
- 13mm Girdle
- 14mm Girdle
Studs:
- 12mm Main Studs
- 14 mm Main Studs
- 12mm Head Studs
- 13mm Head Studs
- 14mm Head Studs
вот первоисточник
www.cumminsforum.com/forum/3rd-gen-performance-par...supporting-mods.html
Модераторы: Боня, Vis-A-Vis, 555 (Сергей), badvik, White ShadoW
Наклейка R.D.R.C.
Узнаём друг друга на дороге!
Клубные сувениры и символика
service
Клубный магазин
Мероприятия
Все мероприятия
Популярные группы
Все группы
Новое видео
Всё видео
Новые статьи
2005 Просмотров
1110 Просмотров
592 Просмотров
Фотографии сообщества
Дни рождения
ARCOHUNTER (44), Barrakud (39), ChopperForum (38), darkcorp (35), Dmitry Korsar (45), Iguan (25), knigaotamogne (38), Korsar (45), lily (34), MasalOFF (38), mkk34 (44), morze_new (44), NomeansNo (42), Plahoy (36), SUT (42), tigrrr (25), Tolyan77 (3), Александр (30), Боня (49), Павел80 (36), Роман (35), Руслан (40)
