ТЕМА: Перечень тюнинг компаний
Перечень тюнинг компаний 3 года 1 мес. назад #308384
  • Макс
  • Макс аватар
  • Оффлайн
  • Подробности
    • Спасибо получено:193
    • Dodge Ram 2500 (2002—2008)
На cumminsforum обнаружил перечень тюнинг-компаний по специализации, мне кажется полезно:
List:
1.Gauges- Pyrometer, Boost, Rail Pressure, Fuel Pressure, Tranny temp (Auto)
- Mechanical
- Isspro
- Autometer
- Glowshift
- Eletrical
- Edge Cts
- H&s
2. Fass / Airdog / Raptor/ - Lift Pump
Fass Pumps (Electrical Pumps)
-Fass 95 Under 550hp
-Fass 150 600-900hp
-Fass 220 900+ Hp
Air Dog Pumps ( Electrical Pumps)
- Air Dog 100 Under 600 Hp
- Air Dog 150 550-800Hp
- Air Dog 165 550-900Hp
- Air Dog 200 900+Hp
Fuel Lab
GDP Fuel Boss
3.Auto Tranny
Builders:
- Ats
- Garmon Transmissions
- Suncoast
- Revmax
- Monster Mike
- Goerend
- DTT
- FirePunk
450-550: Tripple or good single disk Torque Converter, Valve Bodie
550-650: Torque Converter, Valve Bodie, Billet input,Billet Flexplate
650-750: Torque Converter,Valve Bodie, Billet input and Output, Billet Flexplate
750-1000: Triple Disk Torque Converter, Bilelt Input/Output/Intermediate, High Pressure Valve bodie, Billet Flex Plate
4. Manual Tranny- You guys are EASY just get a Dual/Tripple Disk Clutch
- South Bend
- Valair
- Kenny's pulling Clutches
5. Tuner:
Programmer:
03-05: Smarty jr, Smarty Sr, Smarty UDC
06-07: Efi Live, Smarty Jr, Smarty Sr, H&S, Smarty UDC
Downloaders: Edge Juice With Attitude, Bully Bog,Banks
6.Cp3-
-Motorsports Diesel
-Floor it
-Industrial Injection
- Fleece
*Arson 3: Good to 600 hp
*Bag Of Parts:
*Dual cp3: 600 to over 1000hp
*Modded cp3: 600+
7. Air Horn Optional
- Afe
- Thrasher
- Hellman
- Banks
- Bd
- CFM Plus
- Pusher Intake
8. Injectors: Depends on ur build
Each company rates there injectors different. Some rate them in Hp other in Liter Per Minuite (Lpm), others rate in Percentage Overs.
- Builders
* Exergy
- 50% over 100hp
- 100% over 200hp
- 150% over 300hp
- 200% over 400hp
* Smarty BBI Injectors
- Stage 1
- Stage 2
- Stage 3
- Stage 4
* Mass Flow Engineering
- 50% over 100hp
- 100% over 200hp
- 150% over 300hp
- 200% over 400hp
* Motorsports Diesel
* Industrial Injection
* Dynomite Diesel Performance
- 50hp
- 90hp
- 120hp
- 180hp
- Custom Injectors
35-90 hp:400-550hp
90-120 hp: 500-700hp
120-200 hp: 700-1000hp
9.Head Studs
-Arp 425 Up to 75 psi
-Arp 625 over 75+ psi
-H11 Studs
-13mm Studs
-14mm Studs ( Requires Block to be predrilled and Tapped)
10. Exhaust Manifolds-
-Ats
-Steed Speed
-Bd
-Stainless Diesel
-Afe
11.Turbos: The turbo combination that are listed is with appropriate fuel and tuning.
- Borg Warner
- Ats
- Stainless Diesel
- Bulleseye
- Ed
- FI
Singles-S300 Based Turbos: T3 Frame
62/65/12:400-550 hp Real quick Spooling
62/71/14: 400-575 Hp Quick Spooling
63/68/12:400-600 hp Still pretty quick spooling
63/71/14:400-700 hp Little bit Slower Spool
64/71/14: 550-700hp
64/74/14: 550-750hp
66/71/14: 550-800hp
66/74/14: 600-800hp
Twins:
Stocker/s475: 350-700 Hp Great for Towing and Daily Driving
62/s475: 400-800 Hp still quick Spool and Good Daily Driving
62/s480: 400-800 Hp
63/s475: 400-800 Hp
63/s480: 400-900 Hp
64/S480: 600-1000 Hp
66/s483 or s488: 700-1100 Hp
S400 Based Turbos: T4 Frame
Billet Wheels and Race Covers will Help With high Hp Numbers out of Each Setup
S464: 500-650 Hp
S465: 575-700 Hp
S467: 675-825 Hp Best Daily Driving S400 Turbo
S471: 700-850 Hp
S472: 700-875 Hp
S475: 750-875 Hp
S478: 750-925 Hp
S480: 800-1000 Hp
i1176.photobucket.com/albums/...dOil/turbo.gif
12. Cam
-Hamilton
-Colt
13.Push rods and Valve Springs
- Hamilton
14. Balancer
- Fluid Dampner
- Ati Balancer
15. Intercooler: 700+ hp If you have the platic ends of the intercooler upgrade soon as u can
- Ats
- Bd
- Banks
- Hellman
- Afe
- Mishimoto
HTT
16. Ladder Bars/ traction bars for racing or to get rid of Wheel Hop
-Cal Tracs
- GDP Ladder Bars
17. Head Work.
- Valve Springs
- Modifing Valves
- Port and Polishing
- Side Draft Intakes
* Hellman
* Banks
* B&B Tooling
* ZZ Fab
18. Water/Methanol Injection
- Snow Performance
- AEM
19. Nitrous Set-Ups
-DEI
-Nitrous Express
-TS
20. Injector and Turbo Matching
Turbo's: S300 Frame
*62-63mm Turbo 30-90Hp Injector
*63-64mm Turbo 60-100Hp Injector
*64-66mm Turbo 100-200Hp Injector
Turbo's: S400 Frame
*S469-S475 Turbo 120-200Hp Injector
*S475-S480 Turbo 200+ Hp Injector
Twins:
*Stocker/475 Set up 30-120Hp Injector
*62/s475 Set Up 60-150Hp Injector
*63/S475 or S480 90-200Hp Injector
*64/S480 or S483 100-200Hp Injector
*66/S483 0r S488 150-300Hp injector
21. If you plan on running 800+ truck.. then its mandatory to get another vehicles just in case the truck breaks
ENGINE BUILDS
Blocks:
- 5.9
- 6.4 (6.7 Block with 5.9 crank)
- 6.7
- Custom Stroker Builds
Rods:
- 12v Rods ( Some people Shop peen and Polish these Rods)
- Carillo Rods
- Split Cap Rods
- Forged Rods
- R&R Rods
- Mikes Rods
Pistons:
- Fly cut Pistons
- 03-04 Bowl Design Pistons
- 04.5-07 Bowl designs Pistons
- Monotherm Pistons
- Coated Pistons
- Marine Pistons
- Custom Pistons
Girdles:
- 12mm Girdle
- 13mm Girdle
- 14mm Girdle
Studs:
- 12mm Main Studs
- 14 mm Main Studs
- 12mm Head Studs
- 13mm Head Studs
- 14mm Head Studs
вот первоисточник
www.cumminsforum.com/forum/3rd-gen-performance-par...supporting-mods.html
Модераторы: Боня, Vis-A-Vis, 555 (Сергей), mmax, badvik, White ShadoW, Эдуард, Чембар
Мероприятия
Все мероприятия
Наклейка R.D.R.C.
Узнаём друг друга на дороге!
Клубные сувениры и символика
service
Клубный магазин
Популярные группы
Все группы
Новые статьи
Вот и закончилось лето 2017г.  Дети ,устав от летнего безделья ,с радостью пошли в школу , кто в первый класс , а кто уже пос...
305 Просмотров
2282 Просмотров
1495 Просмотров
Фотографии сообщества
Поддержать клуб
Сбербанк: 4817 7600 3763 4221
Яндекс.Деньги: 41001113512385
Дни рождения
Alexander Ivanov (31), beha98rus (35), Dima (36), Fuz (28), ihor (31), l ll l old school (40), Shark (49), Storm (39), Tsvetkoff (25), urbanchic (35), Алекс (38), Андрей (30), Владимир (30), Евгений (34)
